Re: 1988 200hp vro no spark
You state: "i have seen this before on stuff which doesnt mean failure but doest look good for componet either".
Wrong! It does mean failure. The stator is he beginning of both the ignition and charging system. See the following.
(Stator "35amp" Melt Down)
(J. Reeves)
The usual characteristic or sympton pertaining to an engine that has a stator melting down is that it will have spark when cold, but will have weak or no spark when hot. Many engines will run fine at first, but after being shut down, then attempting to restart 30 minutes or so later will not start. However, after sitting and cooling down, the engine may once more start and run. Eventually the stator will fail altogether resulting in no ignition/spark even when fully cooled.
This pertains mainly to the 35amp charging stator BUT this problem has also affected other smaller ampere stators. Make a note that the stator on enngines manufactured in and after 1973 are two fold components. There are a series of smaller coils which deliver AC voltage to the rectifier, the rectifier converts that voltage to DC voltage to charge the battery. There are larger coils that deliver AC voltage to the powerpack capacitor in order to energize the ignition.
The 35 ampere stator has two (2) large black coils located (usually) at the rear of the stator. This 35 amp stator runs extremely hot and even though the water cooled voltage regulator/rectifier may be in perfect working order, this type stator will in time have what is called a "Melt Down". This is when those two large black coils start to drip a sticky substance down upon the timer base and the powerhead. The result is that the outgoing AC voltage to the powerpack capacitor drops, and this in turn results in weak ignition and eventually no ignition.
If a rectifier on any horsepower engine has failed (keeping it simple), this results in having the voltage back up at the stator causing the stator to overheat, which in turn causes a stator melt down.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay auction at:
http://shop.ebay.com/Joe_OMC32/m.html?_dmd=1&_ipg=50&_sop=12&_rdc=1
