question about temp switch 84 johnson 50hp
Elektryk
ok i gotta Q about that switch ...
the engine in an 84 johnson 50 hp
does it have anything to do with starting the engine?
lets say its fried and the wires a just hanging there
would it stop me from getting the engine started?
Elektryk
Re: question about temp switch 84 johnson 50hp
and i was just thinkin that if that sensor is not there at all...
wouldnt it get more air???
Elektryk
please i need help with that.... i was trying to start that engine for all day today.. and when it was cranking sometimes it made that noise like backfire or something....
please i already bought 2 new batteries...
Daviet
If you are talking about the temp sender in the cylinder head, no, it will not have any effect on the starting of the engine.
If your engine will not start check the basics first, compression and spark check. If those are ok, move on to the fuel delivery system.
Elektryk
ok... spark ok compression n/a... fuel ok except primer...
whats next?
i did over heat the engine tho...
Daviet
If you overheated it enough to melt the temp sensor, I think a compression test is a must. Borrow a compression tester and check it, might be your source of the problem.
Elektryk
yes i did melt the temp sensor.... i get the compr. thing tommorrow
boobie
If you overheated the mtr enough to melt the temp sender wire you probably blew a head gasket and who knows what else. Start with a compression test first and go from there.
Elektryk
before i test it what compression should be?
i know that it should be fairly the same on both cyl.
im new to this soo.. little help would be great :)
Daviet
They don't list compression specs, to many variables. I would hope to see something in the 100-125 range, within 10% of each other.
Elektryk
ok im gonna go and get it
i should have the results in about an hour
Elektryk
ok im back with results
top cyl.
85 with plug in
95 without
bottom
125 with plug in
135 without
the top one is where the temp sens is...
so whats next? :( :confused: :(
Daviet
How did you get a compression reading with the plug in. Remove both plugs and check compression for accurate readings.
By the numbers you posted you have a compression problem on #1 cylinder.
I would remove the cylinder head and check the cylinder for damage. Maybe you will luck out and only have a damaged head gasket.
Elektryk
yea sorry for that i meant the top has ### with bottom plug in :)
ok so ill try and get the head off tomorrow and maybe take some pics
how much are the gaskets? and maybe perhaps there is a way of making my own? :) :) :)
Daviet
No, you can't make your own. Let us know what you find.
Elektryk
Hi
I remove the cylinder head and didn't see any damage in cylinder #1 it look like cylinder #2
I see some oil in water canals head
whats next?:(
Daviet
Looks like the head gasket was leaking between the cylinders. Make sure head is flat, itstall new head gasket, torque to spec, run engine to normal operating temp, retorque head gasket and then recheck compression.
Elektryk
does anyone know the torque specs?
i got the torque wrench but i dont know whats the bolt sequence
Elektryk
is that it?
18 to 20 foot pounds is correct, to be tightened in the following sequence.
8...10
5....6
1....2
4....3
8....7
