1999 225hp johnson vro pump questions
joe91170
I just purchased a 1999 Ranger with a Johnson 225. Runs beautiful, but to eliminate any future catastophies should I change my vro pump due to the age of the motor or is the one on it more reliable than the older versions
jonesg
Re: 1999 225hp johnson vro pump questions
You should have the newer OMS pump, just make sure the alarms all work.
I wouldn't change it unless it leaks or goes weak.
joe91170
thanks for the advice .
fisherman912
I agree with jonesg. If the system is working properly, you couldn't ask for any better. You may want to mark your oil tank level with a piece of tape just to confirm oil usage if it is not obvious.
