Mercruiser Tee valve assembly
VeeSporty
Good Evening,
1986 Mercruiser 230, outdrive upgraded to A1 G2.
Boat has lived in salt water for years (unfortunately).
Recently found rod and springs inside Tee fitting badly corroded.
Question - After I replace the rod and springs, how do I know how much compression to put on the springs?
Thanks.
muc
"Retired" Association of Marine Technicians...
Re: Mercruiser Tee valve assembly
If I remember right the nut gets tightened until it bottoms out at the end of the threads.
Good Luck Muc
Ayuh,... The Check-balls aren't used with the Gen.II drives...
