So the plug got left out on the trailer yesterday and needless to say we took on some water. The boat got on plane twice from the ramp(7min run time tops) then started sputtering and stalled. Found back compartment full of water which ment water above fuel tank. Ran bilge and emergency bilge and started paddling. Engine finally started after 30-40min but engine sounded quiet and kept stalling shortly after putting in gear. By the time i got back to the ramp it drove up on the trailer by itself which takes some rpms, water was receding to just below tank. My first thought was air leak in the fuel line between engine and tank which may have sucked in. It got replaced today and fittings were tight and no signs of abbrasions. Hoses were dated 1989. When i pulled the hose off the tank it gasps for air. So then i thought maybe the vent line has a leak in it and it sucked water in? I did find that the fuel filter had a crack in it but only leaked when i really pumped the bulb, didnt leak when running on the muffs in drive way. I'm trying to decide if i have water in the tank or not, what color should it turn...? Its getting drained regardless but i wanna know if its there and where it came from....i know i know it came from the lake! Thanks for the help guys.
1991 Lowe 1700v
17ft
1991 70hp Johnson
1991 Lowe 1700v
17ft
1991 70hp Johnson
