jam39vw995
- Sep 7, 2003
- 105
I've searched the other posts and I'm pretty sure I know what's wrong with my friends 165. The exhaust manifold might be cracked and water is getting into the engine. could also be the block and head gasket too so we're gonna get the manifold pressure tested first.<br /><br />This is like the 3rd manifold he's had to do on this engine.<br />The first time it was cracked and then the replacement was defective so hence another. After 4 months of great running it started all over again. Oil foam spewing out the PCV and oil is milky and gross.<br /><br />Does anyone know if this engine has a problem with cracking manifolds? Why would this keep happening? The new manifold was torqued using the proper sequence and amount shown in the shop manual. We are hoping it isn't cracked again.<br /><br />Thanks for any insight into why this keeps happening.<br /><br />Jeff
