1984 229 ci omc stringer 800, Stearing is very hard, im trying to remove the rear cable drum unit off the intermediate to see if its the cable or troubles beyond in the outdrive, manual shows a retaining screw i assume tightens against the stearing shaft, cant see it but feel something underneath in a bad spot to get at. anyone else had this issue?
The stearing shaft has to be pulled out the back to remove the cable drum?
