hello everyone:<br />I was hopeing someone might have an idea what could be causing my current carburetor/acceleration problems. I have a 1988 mercruiser 3.0 that starts up and takes off no problem, but when you try to go from headway speed to accelerate it bogs right down and almost dies. You have to pull back on the throtle and stick like your trying to pull up a skier and then it goes like a dream. There is no smooth transition from slow to fast. The gas is good and has been treated for water, I was going to just replace the carb but want to make sure that is the problem. Any thoughts
