Re: mercury 2.4 efi bridgeport 150
Here's a couple of other things ta make life with a BP easier if it proves ta be in good shape. Just keep in mind, its an old motor and its no tellin' whats on tha inside no mater what your told..........If it doesn't work out for ya, let me know!
Change the vacuum elbow, tha one tha ecu goes to, (Part number 22- 822715), removed the throttle positioning sensor (nla anyway and prone ta go bad) put a blank plate over where it bolts on. Put an A-40 digital box on and just plug it in. NGK : BR8HS gapped at .035"...................D
Oh yeah, ya can also use tha A42 but you will need part number 848405 (I think). Its an ecu harness part that will allow you use your harness without any mods..........
