camper4lyfe
- Sep 9, 2010
- 18
My father-in-law rebuilt the motor in our boat earlier this summer (1987 Four Winns 190 Horizon with the Mercruiser 165 (I4)) after 1 of the 4 pistons gave up the goat in the oil pan (piston skirt broke right off, the other 3 were getting ready to do the same). It was determined at the time that the last time the motor was rebuilt (due to the dreaded wrist pin breakage), the shop over-bored it (.025 instead of .020), allowing too much piston slop.
The motor was bored to +.030, head and block were both decked, valves were done, and the crank was turned to +.010. Essentially, it was a brand new motor.
While out tooling around, we hit a shallow spot and had to get up on plane, and the motor topped out around 5000rpm, at which point it started to make a really BAD noise. We limped it home, pulled the motor, and removed the oil pan and found pieces of copper. The bearings were SMOKED.
The crank has now been turned to ".020, and is ready to go back in with new bearings. The problem being, we want to figure out WHY they got cooked so that we don't have a repeat performance.
Currently, the theory is this: We put a new oil pump on, as well as replaced the o-ring/seal between the pick up tube and the pump. It was noted that when we removed the pick up tube, it was extremely loose (we were able to pull it right out with no problems without removing anything other than the main bolt holding the tube to the block. We believe that the o-ring was not the correct size, even though it was ordered specifically for the motor.
So, after much rambling, I'm asking you this: WHAT type/size of o-ring should be there? We ended up with a standard round o-ring when the seal/ring we removed was either square or an x-ring originally.
I've found one site that gives me the dimensions for the o-ring, but I really don't have anything to compare it to, so any information would be greatly appreciated.
Thanks in advance!
Thanks in advance!
