patternghost
- Sep 9, 2010
- 9
I'm not new to boats but I am new to doing the repair work myself! I bought a 70hp 1978 Johnson, tried it on the hose and it ran great. So I took it out for a test, mostly to make sure the boat that came with it wasn't going to sink. I ran on low speed for about 10 minutes, shut it down and dropped anchor to check out various things on the boat itself (ok, I mostly made sure that my fishing pole was compatible with the boat). Anyway, after about 10 minutes I tried to start it again and it wouldn't start. Tried with the choke, without the choke, made sure the tank was ventilated, pumped the ball, let it sit in case I flooded it, took off the fuel filter and made sure it wasn't plugged, then ended up rowing back to shore.
When I got it home I made sure the spark plugs all had spark. Not sure what else to do except take it to a service shop, but I really don't wanna!
Probably an easy answer, but why would it just not start again after running perfectly 10 minutes earlier?
Thanks!
Thanks!
