strange (to me) charging issue
john dezman
Boat Formula 31PC
engines 454 (7.4) Chevy Bravo 2
(One) engine, at idle, will show appropriate 13+ volts. Advance throttle beyond 1200 rpm and line voltage drop to 10-11 volts.
What might be going on and how do i test and troubleshoot?
thanks in advance.
HT32BSX115
Re: strange (to me) charging issue
Howdy,
Aside from checking ALL the ground connections, (clean and tight), to start, I would pull the alternator and take it to Autozone etc and have them check it.
Vanover
Could be a voltage regulator, most likely built into the alt. They might not be sending out the correct signal/ or geting a bad signal through the ground or power. Lose connection is a possibility. Like mentioned above they can test for these conitoins. Just make sure they get it hot (doing the test a couple of times). Put ti on hard load.
HT32BSX115
Yeah!
I agree on that!
Travis AFB
Home of the C-pive...... You do some of that stuff down there?
