metriccrescentwrench
- Oct 22, 2007
- 2,598
I've got two bad V6 lower units. One appears to be a '96 or newer based on the water pickup. The older one has the snap-ring behind the prop shaft bearing housing, the newer one does not.
What I plan to do is move the driveshaft, pinion, clutch dog, forward and reverse gears, and prop shaft from the newer gearcase (which is cracked), into the older one (which has lost reverse), and end up with a functional lower unit.
Will there be any issues with doing this?
