Hi,
I need some advice on a prop. I just bought a 1994 Baja 180 islander and would like to change the prop. The one that came on the boat is a composite material info that is stamped on the prop is this 4x345x508 and 4x13.6x20 and m4550L. with this prop it runs about 42 to 43 mph but turns the engine around 5200 to 5300 rpm at wot. I think this rpm is to much, not sure.The boat weight is 2400 lbs it has a 4.3 mercuriser in it and I normaly have 2 adults and 3 to 4 teenagers in in. We mostly use it to ski so I would like a 4 bladed prop.Any help would be appreciated.
