Hello,
Just bought a cottage that came with a 20' pontoon with a 1999 Johnson 50HP oil-injected 2-cycle outboard. It starts great, but after running for about two minutes, the "No Oil" light and alarm goes off, and thirty seconds after that, the engine sputters and dies. At this point, the fuel line has lost all pressure. The engine can be kept running indefinitely by manually keeping the fuel line pressurized, but the "No Oil" alarm remains triggered. I have changed the pressurization bulbs on both the fuel and oil lines.
If the fuel pump is the culprit, would this also cause the "No Oil" alarm? If not, any other ideas would be greatly appreciated.
Thanks in advance!
Thanks in advance!
