I bought a 1990 70 Johnson and the Carb bowls were leaking so I got three OEM kits and rebuilt carbs. Put them back on and it run like a dream. The next morning I tried to start it and engine was turning over very slow and all three carbs are flooding and leaking out of throttle body. I'm very experience with engines and carbs. Im a master auto technician. I'm not sure what else I should check before I pull carbs again. I set floats at .725 measuring from Carb body to float. The primer does not leak when I press bulb. I'm having a hard time thinking that I messed up all three carbs unless I had the wrong specs for the levels. Anybody have any ideas on what to do next
