gravysandwich
- Jun 2, 2010
- 26
The last couple of times I have been on the water, my 1996 Johnson 112 VR has over revved out of the hole. It was so bad, in fact that I would have to get out of the throttle for fear of doing some damage. The good news is that the problem would correct itself after I tinkered with the trim long enough (or so I thought)
This weekend the same thing happened again but during acceleration I heard the motor "clunk" into a full trimmed down position. It seemed as if the trim temporarily lost pressure and the motor dropped all the way down.
My trim fluid is topped off. The relays are working OK, and the rams appear to be working properly. Is this over revving the motor changing trim orientation under acceleration, creating prop ventilation? If so, do I need to bleed and re-pressurize the trim system?
Gravysandwich
Gravysandwich
