Nautique93
- Nov 10, 2008
- 40
1983 Mercury 70. SN 9353189
I replaced trigger and stator last summer because they were both out of spec. This cured the problem of not revving past 4000 rpm. Now with less than 20 hours on the engine, the symptoms have returned, and the new trigger is now showing out of spec. What could cause this?
Readings are: Brown-white/black 824 (spec is 700-1000 so this is ok)
white-violet 1645 (spec is 700-1000)
The trigger i replaced last time was reading even higher:
Brown-white/black 1229
white-violet 2498
These readings are all taken at room temperature, and increase when engine is at operating temp.
Thanks, Peter
white-violet 2498
Thanks, Peter
