Re: hard starts with 50 hp
turn the mixture screws a 1/4 turn to the left first and see if it improves -
test trigger ( wires removed ) with a voltmeter for 4-5 volts when cranking - all good there - turn the idle up to about 1100 rpm on muffs . post back with your findings and dont turn up the idle without first checking teh trigger or you will be masking an inevitable failure out at sea .
