bassboater69
- Sep 7, 2010
- 1
2004 rinker 250 merc 5.o
the fluid in the resovoir is brown. i hadd steering issues that turned out to be the cable. (replacement ordered 3 days)
How can i drain the old fluid from the power steering , refill and bleed air?
from whet i can see there is 2 cables going to the res. 1 to the hyd pump and the other to the cooling.
I dont see a drain and or bleed plug. I can suck out the fluid with a oil drainer n replace a few times but fluid stays brown.
Thanks in advance
Thanks in advance
