I just brought home a 97 Maxum with Force 120 on it. Now What should I check for? I will be running a compression test to make sure pistons are good. Maybe do a tune up and rebuild the carbs and what about lower end, I dont know If there is any way to check for oil and stuff? Can someone fill me in a little bit? Old owner cranked it up in front of me and it started right up. A lot of white smoke so its oiling good. He shifted forward and backwards and saw the prop spinning and balanced. I just dont want my first time out to be a nightmare you know. Any help and advise will be greatly appreciated guys.
