Mark42
- Oct 8, 2003
- 9,334
You may have read my posts about looking for used outboard to repower my 1985 Bayliner project boat with the custom hard top. Have been looking at lots of used motors and used boats and only come away frustrated.
At this time, my wife just wants me to go buy a new motor and get it over with so she doesn't have to listen to me complain and take off every other day to check something out and come back and complain. Hmmm.... not such a bad idea.... What are the interest rates? LOL!!!
The 1998 Evinrude 90 hp w/tilt/trim is the motor I am looking at right now. Available as a complete rebuild from a few different shops, its within my budget (sort of) adds about 50-70 lbs to the boat, and is a proven performer with lots of parts and support. So that is my current choice to repower this boat:
My Bayliner 1600 currently has 85hp Force (no T/T) and a US Marine (made by Morse) concealed side mount control using 33-c cables. The easiest way to repower is to just buy a new/used Johnson side mount control and bolt it on. But I would like to keep the concealed side mount control for aesthetics. So I found the cable end kit that lets the 33-C cables from the Morse unit work with a '98 Evinrude 90hp (about $16 on iboats). But the rest of the connections need to be hard wired. Such as the ignition, neutral safety and over heat alarm.
So I am looking at various "adapter/conversion" cables to use with the 1998 model Evinrude to allow connection to the existing ignition, alarm, etc. The only option the boat currently can't support is tilt/trim. So both a tilt/trim switch and gauge need to be added. Both are easy enough to install. But I would rather have the tilt/trim on the control, rather than a rocker switch on the dash.
So.... any suggestions or comments about installing a 1998 Evinrude 90hp as a repower to the 1985 Bayliner with 85hp Force are greatly appreciated. I tend to list every aspect of a repower in detail, and the controls are an issue for me right now.
BTW, does a 1998 Evinrude use the big red connector under the cowl or something else? (I think its something else - something I am unfamiliar with).
Thanks!
Thanks!
