15hp 1974 johnson help
johndde
bought a used 15.now the thing wont go in neutral.i do have the tiller off cause im waiting for a new gear to come in.do i have to have the gear to get it in neutral
bktheking
Re: 15hp 1974 johnson help
There is a metal lockout on the shifter that makes contact with the mag plate. With the tiller off you probably have it rotated to fast or above shift, pull the cowl off and look, left side under the flywheel looking at it from the front.
johndde
can it only be repaired with tiller on?my guide has no section on this
bktheking
Nothing to be repaired, do you see what I am referring to?
johndde
yes i do and metal piece is holding it up.how do i get around this?
bktheking
It's there for a purpose, to prevent you from shifting into gear when you have it above 1/4 throttle, remove it if you want but you are running a risk.
johndde
the throttle wont move think its seized in the inner gear control.took a torch to it and didnt realize the part was plastic to release and bam melted.ist hard to replace the part?
