mwilliams43
- Sep 5, 2010
- 4
Needs some help with this. I have a 99 Maxum with a 4.3L alpha 1 gen 2. Milky oil was found earlier in the season. Engine was drained, oil and water came out separate along with a bit of milky oil. Cleaned out, refilled, shop tested, lake tested, could not duplicate problem. They contributed it to my error with a engine flusher. Evidently I may have let the flusher on for a few minutes, with the engine off. (put the engine cover back together, cushions back on, etc). Shop told me to keep an eye on the oil level.
I have been keeping an eye on the oil level. Level seems fine. Boat has been running fine. I am out every other weekend.
Today, I decided to open the oil fill cap. I found a mayonaise type substance in my oil fill tube and cap, along with some condensation on the cap. Am I having a water issue again or what could be the explanation for this problem?
A side note, compression test was fine when the earlier problem was discovered. All six cylinders were firing normal.
Thanks for any advice.
