Re: how do i remove spider cracked gelcoat in cockpit
Basically Gelcoat is more like Fiberglass than it is like paint.
Actually, it
is fiberglass - polyester resin - the difference is gelcoat has color and extra UV resistive chemicals added - and no glass fabric, but it's the very same base resin.
Once that 'bowl' gets too big, you're also affecting the structural integrity of the deck itself.
Gelcoat is typically about 0.020" thick (paint, 4 - 5 layers is around 0.010" thick total.
A Dremel with a depth collar and a pointy bit (not the one shown) works perfect for widening cracks without creating the wavy surface a grinder does.
Once the cracks are filled, then you sand the whole surface without having to deal with leveling valleys left by grinding cracked areas.
Another option is try a fiberglass faring material to try and cover the spider cracks on the actual top. It's much easier to fix a flat surface than it is to fill a 'bowl'.
Cracks cannot be covered - paints, gelcoat, fairing compound all just bridge, but don't fill. The cracks reappear quickly - but you've already experienced this.
Would a power washer be ok to use to remove all the paint from the deck first then grind out the spider cracking areas and repair with new gelcoat with non skid material rolled?
I've never seen a power washer that would remove anything that wasn't already loose - even a steam cleaner doesn't touch attached paint.
These days non-skid comes as ground rubber you mix into gelcoat or paint or, for gelcoat, there are overlay mold sheets you place on wet gelcoat.
Second where to i purchase the correct orbital sanding disks to remove gelcoat? which ones should i purchase? Thanks for the advice. this looks like a fall project.
A specialty plastics supplier if you have one. Otherwise, go to NAPA or another auto bodyshop bulk supplier. They should even be able to advise you on the grades of disks.
