michaelbluewolf
- Aug 8, 2010
- 46
Hello Again,
Just used Tal-Strip to remove most of the bubbled paint on the bow of my Neptune. Question is, can I use a jitter-bug sander to finish the cleanup around the edges and the moulding for he rub-rail? All the screws are fouled and can't drill the s/s screws with the drills I have. If so should I use 220 Grit or will this damage the hull? I am an auto mechanic and not a boat mechanic. If the lower hull paint, brushed on by PO over the a Nice white finish underneath is not peeling can I just lightly sand it and repaint the hull?
I have not a clue, the paint on the hull looks to be adhereing well, except on the splash gunwale on the starboard side. Which I will sand and reprime before repainting.
Thanks in advance,
Mike the Mechanic
Thanks in advance,
Mike the Mechanic
