If the problem is in the manifold, 0393942. If the problem is in the tilt cylinder, 0390007. If the problem is the trim rams: http://forums.iboats.com/showthread.php?t=237028&highlight=trim+cylinder+seal+kit
You still could have leakage around one or more of the valves.
