buckeye boater
- Sep 4, 2010
- 2
I recently purchased a 1988 18' 7" bayliner capri cubie cabin with a 125 Force engine. This was a bank repo boat that I got for $200. It needs a little work and hasn't been in the water since 2003, but feels solid. I cleaned out the old fuel and put in new with oil. I hooked up a garden hose and it fired right up. After a few minutes a buzzer came on under the dash. I shut it off but the buzzer kepted coming on if I turned the key. Also there was light smoke coming out of the exhaust and it smells like something burning. Would this be normal for an engine that hasn't run in about 7 years and what is the buzzing
Also, does an outboard motor have an alternator on it or will using the radio run the battery down when the motor is running.
Last question, when I lower the motor it does not go all the way down. it hits a bar and i'm not sure how to move it or do I take it completely off. Once the motor is raised it slowly goes back down. Is this an easy fix?
