Re: Alpha I Water Pump Question
the plastic tube is for guiding the water passage tube from the upper into the top of the pump when reassembling the drive halves
since it is melted, at some point there was not sufficeint water coming out the exhaust and the hot exhuast gases melted the tube
be sure to check the water passage tube at the bell housing for kinks and inspect the oil cooler on the engine for blockage - weeds/debris
also, if this is an Alpha One with the plastic housing, it is a good idea to replace the pump base assy and gasket/o-ring at this time
when installing the top pump housing over the impeller, rotate the driveshaft clockwise, it always turns this direction
