Ok, here we go.......
Motor has been running fine but....... for the past 6 weeks I have had a problem keeping the battery charged. Was good for 2 to 3 times out and then would have to swap with a fresh charged battery. Also if the boat sat for a week or so the battery would discharge and have to be swapped out. So I'm thinking something was drawing current even when everything was off. Both batteries I have are less than 2 months old.
Last weekend I swapped for a freshly charged battery, boat started fine, ran fine, but noticed that voltmeter was at around 16 to 16.5 volts. Parked boat on Sunday, went to take out on Thursday. Battery needed to be changed which I was accustomed to...... Changed battery, engine turned over like a bat outta hell, but would not fire for anything.... I figured it was flooded so I just let it sit til Friday afternoon. Went out and tried the normal starting sequence. Turned over fine but still no spark. Disconnected black/yellow at engine and still no pop.
Maybe more info than needed but I didn't know if the draw / discharge issue lent any ideas as to what may have quit working...... HELP!!!!
