Re: Fixing a Volt Meter Problem
Many times, there's a hatch inside the cabin, behind the gauge panel. If not, sometimes there are screws on the face of the panel. They will be covered with plastic caps. Pry the caps off, unscrew the panel from the dash. There should be two brass nuts holding the Voltmeter to the dash.
CHeck the voltage at the gauge. Volt meters are pretty reliable. Rule out that you have a bad connections.
