FreeBeeTony
- May 15, 2002
- 3,991
bondo, just thought i would let you know I put my drive back together. new gears, bearings, bearing carrier and seals in lower unit and new seals in upper. filled with lube tonight, will check for leaks in the morning and will hopefully test run in the bay tomorrow. wish me luck, I will let you know if it survives! I think it will....
