I have 2 1956 Evinrude 30's. One a Lark and one a standard with a tiller. I finished restoring the 1956 Lyman I am going to put one on (and the gator trailer) so now I am working on getting one or both running. Started with the Lark and put new points condensers and coils in it, along with a new impeller. Tried starting it yesterday in a barrel on a homemade stand and wasn't getting gas past the carb. Took the carb off and apart today and it was clean but I cleaned everything. Tried to fire it up again and still no gas past carb. Pressure tank doesn't seem to make or hold pressure - only enough to fill the glass bowl. When I take the cap off the tank after pumping it - no pressure whoosh. Took it apart and used carb cleaner on pickup tube valve near through pick up screen and got it to shake. Put it back together, pumped it a few times and had gas coming out around top of tank- grrrr. SO, I am about ready to see if I can convert the motors to a single line with fuel pump. I read the info on the FAQ section. It doesn't appear that either of the 30's have the covers with the raised bosses. Are these covers interchangeable from various years/models? If so what am I looking for? Thanks for the help (sorry for the long post).
This is what I am putting it on:
