OK, I'm at a loss now. 60hp 3 cyl. Merc 1984 model. Just rebuilt. Runs fine until under a load, then #2 cylinder quits firing or fires intermittently when rpm's reach about 2500. I have now replaced the stator, the trigger, the switch box and the coil. I have adjusted and readjusted the carbs a dozen times and checked the fuel pump twice over. It still falls off between 2500 & 3000 rpms. All three cylinders are showing 120 psi compression with no other noises or issues, so my rebuild is holding together. What the heck am I missing?!! I've never had this happen before and now I am at total loss.
HELP!!
HELP!!
