Re: 2003 90 hp 4 stroke yamaha smoking
compression test really isnt worth much, a leak down test is faster and more accurate.
a leak down test simplified.
that cyl at top dead center on compression stroke is a sealed cylinder.
may not have a perfect seal.
thats what we wish to know.
so we inject a known air pressure into the cylinder and monitor how much make up air has to be injected to maintain that known pressure.
this is indicated as a percentage of leakage from the cylinder.
by listening at the oil fill,intake or exhaust we can tell where the leakage is.
less than 15% and your good to go.
next time you shut the engine down try trimming it up about half way, see if that helps as per the yamaha tech bulliten, or ask your tech for a copy of it.
we see it a lot with lift kept boats.
leave the engine trimmed down after shuttng it off and the spark plug end is now tilted downward, any oil behind the piston can make its way past a ring or ring end gap and is now in the combustion chamber, at the next start up the oil is burned off.
rather normal but ring seal is easily tested in about 10 minutes.
takes longer to get the hood and spark plugs out than the actual test.
