Beefer
- Aug 4, 2008
- 1,737
It appears as though I need to completely clean my tank. It's an 80 gal aluminum, and I don't think I can (easily/realistically) get it out without it becoming a major project. I've searched and read through post relating to this, and this is what I've gleaned from those;
1) there is nothing I can add to break down the 'shellac' so it will run through without clogging
2) denatured alcohol will clean the gunk off
3) rocking the boat with the tank full of nuts and bolts will expedite the process
4) 'polishing' the gas (cycling through filter(s) multiple times can clean up the gas and make it usable (it's fresh non-ethanol)
5) run it as is, and change filters after about every use
6) hire a tank cleaning company
7) don't use a shop-vac
8) use a stick with a rag
So from this info (and more), if I want to do this myself, I could drain the tank, and put in some denatured alcohol. First question is, how much denatured alcohol would I want to use? 1 gal? 5? 10? 80? After I do that, and then drain the denatured alcohol, can any residual alcohol be left in the tank, or do I need to let it evaporate out?
Is there a better way, or a way you would do it, without removing the tank from the boat?
