anothersteveg
- Feb 15, 2009
- 14
Hi All.
We put off the big boat purchase for a little while and so I got a "project boat" to keep me busy.
It's an old 16 ft. Lowe fishing boat, came with a '73 Evinrude and I need some help in a couple of areas. The motor had sat for awhile and I don't know much about it. I replaced the switch, cleaned the carbs, drained the gas, put in new plugs, and it fires right up. The bottom cylinder has lower compression (170 on top, 140 bottom) and I will eventually have to rebuild it.
Where my immediate concerns are, is with the lower unit. I dropped it to change the water pump and saw lots of water and bad oil. I also noticed the water pump only had 3 bolts on it, and the impeller was cracked at the hub and the key thing had come out. I fixed all that and have a new pump on that is working good.
How concerned should I be with the oil right now? Could the water have gotten in somewhere from a loose water pump cover or seal? I filled it back up and ran it again (on muffs in the driveway). It doesn't have the right gear oil for the Evinrides and so I know I will need to drain it again anyway I just thought I'd try it a few times and see what the oil looks like when I drain it again. If it isn't bad I will take it to the lake and see what happens?
Any thoughts?
Any thoughts?
