DukeDelago
- Jul 17, 2009
- 46
Looking for some ideas here. After extensive work my motor is starting fine and stays running at idle. On the hose everything seems perfect. When I went to the lake to test, I'm having problems. Motor is severely lacking power and takes a while to plane, and will max out at 4400 rpm/30 mph (normally 4950 or so and 36/37). The motor seems to bog down severely on the hole shot, but eventually gets going and runs relatively ok but again, lacks power. I've tried adjusting mixture several times and has an effect, but can's seem to get the problem solved by leaning or enriching the mixture. Just rebuilt the motor and have 125-135 psi on all four cylinders and getting spark on all four as well. I have recently removed, cleaned, and reinstalled the carbs which had the effect of eliminating the "wont run in idle" problem but I'm still not getting full power. This problem began suddenly after being caught in a huge downpour a few weeks ago for over an hour (thank god for bilge pumps!). The boat fired up, ran well for about a minute, then lost power all of the sudden. Limped back to the ramp and have been having problems since. Is it possible I've gotten water in the fuel supply and that this is causing all of this? Any help would be greatly appreciated folks!!!!
