buickbonehead
- Aug 31, 2010
- 1
I am currently working on an 82 Johnson 25hp and a 71 Johnson 25 hp. Both are tiller handle. I?m not mechanically handicapped but I haven?t done much work on outboard motors. I?ve been around them plenty but never owned one and quite frankly as long as they started and ran I didn?t much think about it. Geez that statement sounds like my wife talking about her car. Most of my experience is restoring cars?as a hobby?.not professionally.
Questions are:
The 82 has a ?tell-tale? water stream squirting to show the water pump is working. Should this be a constant stream or can it intermittently stop and start. It squirts the vast majority of the time. I?ve only run this in a barrel so far.
The 71 has no ?tell-tale? squirting at all. Does this motor not have one or is the water pump not functioning. It runs fine, but while idling in the barrel it seems to try to jump into gear and then goes back to neutral. It works fine when in forward gear, haven?t tried reverse. Is this a linkage problem or the lower unit on its way out?
Lastly, when looking for parts motors (Johnson or Evinrude) is there a span of years that are basically the same and parts mostly would interchange. The does appear to be difference between the 82 and the 71.
Thanks Rick
Questions are:
Thanks Rick
