i recently purchased a 1985 25xd. The guy said it torques to the left some, so i purchased and installed it on my boat. when i went to try it out, it torques severly to the left. Not a little but severly. i adjusted the trim tab but it did not help. after further inspection i was wondering if it could be the upper motor mounts that are bad. is this a common problem or am i overlooking the real issue. the prop looks like it is true and the motor looks like it is straight. the skeg is not bent. can anyone give me some advise
thank you
thank you
