Thanks for reading this. I'm grateful for any advice.
This is a kicker on a 20' aluminum boat that I recently purchased. This has been used extensively in salt water. It has a few issues (e.g., deformed swivel bracket), but the one I'm focusing on now is the cooling. I noticed that there is no water coming from the tell tale.
I have removed the lower leg and replaced the impeller, housing, grommet, etc with a water pump kit. With the leg off, I've fitted a plastic hose to the bottom of the copper tube. When I run water up the tube, there is still no water coming from the tell tale. (the water does discharge through the open leg housing as well as through the vent at the lower aft end of the motor (upper leg?).
I've run weedeater line up the copper tube as well as into the tell tale, using an electric drill to give a roto-rooter effect. Still no discharge from tell tale.
I removed the thermostat and cleaned out plenty of grit. With the stat out, I back-flushed by running water into the lower copper tube. There was more crud that came out through the stat housing, with abundant water flow.
I reinstalled thermostat but still no water from tell tale and, when I put water under pressure into the tell tale, it doesn't discharge anywhere.
So that's where I'm at now - wondering what to try next. I could dismantle the head and clean passages from there, but I'm hoping that there's a way to resolve this without having to remove the head.
I see that there is a pressure relief valve somewhere on this engine. I thought that might be an access point, but I can't find it. It's showing on the parts diagram, but perhaps it is internal.
I would appreciate any suggestions.
