Need help to wire tilt / trim Johnson 48 SPL
Georgia10
I need help wiring tilt trim motor to Johnson 48 SPL. I have 95 Sunbird boat with factory 48 Johnson. The boat has trim guage and also has control on throttle handle but no factory tilt and trim. I bought good used Evinrude 50 tilt trim that will fit this 48 motor mount. It has the blue wire (up) and green wire(down). Under the motor cowl the wiring harness from the boat has a 5 pin plug. Is there a adapter or relay harness to make this work. Was told you can make 30 amp 2 relays to tap into wiring. Need help. Has anyone dealt with this problem?
