Dual 70 hrs johnsons
jtwayne
Ihave dual 70's on my boat with no room for a kicker i had a trolling plate installed on 1 motor, and someone told me i should not run only one motor at a time due to water being forced up into the powerhead of the one that is not running does any one have thoughts?
trendsetter240
Re: Dual 70 hrs johnsons
Welcome to iboats!
Someone told you nonesense. There is nothing wrong with running only one motor when you have twins. Water can not be forced up in to the powerhead of your second motor this way. Even if it could, it would not cause damage.
I have twin 70hp evinrudes (only one is installed at the moment). What type of boat do you have and can you post some pictures of your setup?
Cheers
jtwayne
i have a 18 ft starcraft with twin johnsons my first boat got smokin deal 1800 bucks
scoutabout
I'm thinking the impeller would prevent this issue as it's not turning on the engine that's off and therefore blocking the passage of water?
One other thought - if you do a lot of trolling I'd alternate which motor I was running just so the total hours remains about even across both units.
