No Oil Light, Please help
Pat G.
A friend has a 2000 Johnson 150hp. It was dirty and he sprayed engine cleaner on it and washed it off like the instructions said. Now the no oil light is on and it is not oiling. Any help or suggestions please. Thanks, Pat
Chris1956
Re: No Oil Light, Please help
you need to tell us the model number. I assume it is two stroke with an OMS oil injection Pump? If so, check the connector to the OMS Pump and see if you knocked it loose. Run some 50::1 premix fuel until you sort it out.
