Re: Trailer Lights not working
Totally agree. Before you go any farther, buy a trailer light tester or use a multi-meter if you have one.
Make sure there's power at the plug for each light function (tail, stop, turn) so you eliminate the vehicle as a source of the problem right off the bat. That or you confirm it.
I had a similar problem last year with my Olds Bravada. My running lights on the trailer wouldn't work. I had turn and stop, but no running lights.
Turns out, after I drove myself insane trying to figure out where the "bad ground" issue was on the trailer, the problem was a blown fuse in the vehicle. Guess what? Now I own one of those quickie tester things.
But this was not obvious because the running lights on the vehicle were still working. The fuse that tuned out to be bad was NOT the running light fuse, but the manual's fuse box schematic gave it some totally vague name like RLTTRLR or some such.
I only found it by pulling out each of the 100 fuses in the 2 fuse boxes one at a time until on the 78th fuse I found the bad one. Then I looked it up. I would NEVER have known based on the crappy description in the manual.
So now I know that each prong on the trailer lights is seperately fused on my vehicle. All of them have gibberish names in the manual, but now I kind of see the convention, there's RLTTRLR (running lights trailer), there's TRNTRLR (turn trailer) and so forth.
Bottom line is first to figure out if the problem is with the vehicle or trailer. $5 for a simple tester will rule the vehicle in or out in 10 seconds.
Grouse
