Aquaholictomc
- Aug 23, 2010
- 4
Ran a compression check, which came out good but I can only get about 2000 rpm's out of engine when I run it.
I have spark at all three cylinders but when I put my hand over carb intake I can stall engine on cylinders 1 & 2, which is normal. When I try to stall the engine on the lower carb, I have suction and you can see the fuel but I can't stall engine.
I can put my hand completely over the carb and it still keeps running. I'll pull off the carb tonight although I did rebuild all three carbs earlier this year.
Does anyone have any other idea's??
