I have a 1994 Johnson 150 hp Ocean Runner motor that I got used.
The issue I am having with it is it often floods itself when first started. Or if it starts it will run for about 2-3 minutes then die, just like someone shut off the switch, then after a little turning of the motor and choking it - it will go again. Once it runs for 5 minutes all it takes is a touch of the key without choking and it fires up all day long.
The other issue I have and I am not sure if they are related that is why I am posting both of them.
While running down the lake the motor will cut out, again almost like someone is shutting off the keys then turning it back on. Sometimes it will run fine for 1/2 the day, then the other half it will cut out like that, sometimes it is so bad that it will just kill the motor while running full throttle across the lake. Motor will die, I hit the key it fires right back up and off we go again. Sometimes while doing this it will start cutting out bad. There doesnt seem to be a rythm to when it does it. Like I stated sometimes it will run hard all the way across the lake and not miss a beat.
Any ideas I sure would welcome
Thanks
Thanks
