The motor is an 85EL77, 1977 Johnson 85HP.
See the previous thread regarding fuel system problems I had today. (http://forums.iboats.com/showthread.php?t=434536)
Thinking about changing the fuel pump since it hasn't been done since I inherited the boat just as preventative maintenance.
Trouble is, fuel pumps are $$$, so I wanted to just get a rebuild kit.
No rebuild kits are specified for this year/model of engine that I can see, and the factory service manual says the fuel pump is serviced as a unit.
However, according to the shop.evinrude.com site, the pump for the 1978 85HP is a 0385784
Take a look at the 75HP model for say, a 1980 motor: same pump number. 0385784.
Take another look at the 75HP model for 1975: same pump number, 0385784.
Now the strange thing is, you can find carb kits for the 75hp model for those years, both 1975 and 1980, and they are the same.
Does it stand to reason then, that if the entire pump is the same part number for the 1977 85HP as well as the 1975 75HP and the 1980 75HP, then the pump rebuild kit for those 75HP motors should work on my 1977 85?
It looks like it's some sort of oversight in the parts application book, but I can't be sure.
--Geoff
--Geoff
