I was coming into dock yesterday and my boat stalled. I could not get it to run after that except in Gear at a higher RPM, it kept stalling out in neutral. NelsonQ and I looked at the throttle linkage this morning and everything was operating normally. We pulled off the air filter to see if it was stopping the airflow, it was not. The stamp on the air filter stated the motor should operate at 650 RPM in neutral, we made this adjustment on the idle screw.
The boat ran fine for most of the afternoon however after a couple of hours on the lake tubing and running it at about 3200 RPM when I put it in neutral it revs at 2000 RPM.
Hurricane 20 ft Fundeck
As stated the boat has a 4.3 L Mercruiser, Alpha One outdrive, looks to have an inline water separator and I had the Impeller replaced about 3 weeks ago by a marine mechanic.
If anyone has ideas as to what is going on please let me know.
