Hello, i have a few questions. I have a 1969 Johnson that is not peeing and there is milky oil in the gear case. Will a broken waterpump/impeller is cause water to enter into the gear case?... There is oil coming out of the "pee hole"(not sure if it is gear oil or 2 cycle oil) . Is that normal considering the water pump is not working? How do I confirm that the water pump is the only reason the motor is not peeing. Is there way to check if the water route is clogged without disassembling the entire motor?
Thanks, David
Thanks, David
